Every once in awhile my motor squeals with a belt off it still squeals and it only does it every once in a while.
May 13, 2020 at 2:48 PM
✓Experienced Mechanic
Can you provide the engine size? Also, is it possible for you to record the noise and upload it for me to hear? I will also need to know if it has a manual or automatic transmission.
May 14, 2020 at 12:38 AM
WADESEBASTIAN
MEMBER
It's a v6 and it's an automatic transmission. i can't record the sound because it only does it every once in a while. it sounds just like the belt, but i took the belt off and it was still doing it.
May 14, 2020 at 6:05 AM
The idea that it sounds like a belt but doesn't do it with the belt off is a tough one. Could you tell if it was coming more from under the vehicle and not so much the engine compartment? The only thing I can think of is if there is a bearing or something rubbing at times.
