Battery issue
130,760 MILES
NESSAC1984
It is making. A load noise like a scratching sound. maybe some belt? Then today my battery died. Charged it was doing fine then I had to recharge battery.
Jun 14, 2017 at 4:09 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test, after charging make sure terminal ends are clean. then check belt, not cracking and tension-er it may be slipping recommended replacement for belt and tension-er is 60,000 miles
Jun 14, 2017 at 10:54 PM
