code p0420
167,000 MILES
DENISE NICOLE WOODEN
It is giving a code p0420 and I need to know what it could really be for. sure I am a single parent and do not have lot money, but I got to get tags on the car and I do not know what to change for sure.
Mar 14, 2017 at 12:01 PM
CARADIODOC
  • 34,415 POSTS
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Most commonly this is due to a failed catalytic converter.
Mar 14, 2017 at 12:19 PM
Is that the same as the o2 part? And would that be the first part I fix to get my check light off? And is it real expensive to get that other part fixed ?
Mar 14, 2017 at 1:12 PM
  • 55,770 POSTS
Hi Denise,
No unfortunately, the catalytic converter is more expensive but and you can find one Amazon.
https://www.amazon.com/gp/product/B0049J8WTE/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B0049J8WTE&linkId=7310c879f53b538ccf2d64d77169161b
Here is a guide that will help you know what you are in for when changing it out.
https://www.2carpros.com/articles/catalytic-converter-replacement
and when you are done you will need to clear the codes
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let me know if we can help you further.
Best, Ken
Mar 15, 2017 at 9:34 AM
