Codes 07E8 and 07E9
98,000 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
KIM GREENLEAF
Control module codes 07E8 and 07E9.
Feb 18, 2022 at 3:28 PM
  • 110,246 POSTS
What symptoms are you experiencing? I ask because, although the codes relate to the same module, they have different meanings. A 7E8 engine code indicates a leak in the evaporative emission control system. On the other hand, the 7E9 code is related to the engine powertrain, specifically with the transmission.
I need to know how you retrieved these codes. Also, they are very basic and don't identify the specifics. If you haven't, you should consider scanning the can-bus system. CAN stands for controller area network. Basically, all the modules/computers are tied together via a few wires. This type of scan will identify codes regardless of the module they are stored in.
Here is a link showing how it is done:
Let me know if you are able to scan the computer and the codes which are stored.
I will watch for your reply.
Feb 19, 2022 at 8:06 AM
