Fuel pump
176,264 MILES
C MARIE REED
Hi how are you? I have a problem and need help .i have changed my spark plugs and coils and installed a new water pump. Yesterday I changed out my catalytic converter. My car will not stay running . I got it to run this morning at first it would not go over 25 mph without shaking, I finally got it to go over 40 mph then it started jerking and wanted to shut down, when I press the gas it wants to jerk . Could this be my fuel pump? Please help!
Jun 11, 2016 at 3:20 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it. if it is bad also replace the filter.
Jun 11, 2016 at 4:58 AM
C MARIE REED
Okay, I will try that and I will let you know how it goes. Thanks for the help!
Jun 11, 2016 at 5:04 AM
  • 31,937 POSTS
Scan up for any fault codes as well, not all codes will set a check light.
Jun 11, 2016 at 10:43 AM
