Transmission problem
5.7L • V8 • TURBO • RWD • AUTOMATIC
BANKSY44
On my transmission the reverse works, but when I put it in drive it is like it does not want to come out of neutral. So I have no drive.
Jun 10, 2016 at 10:49 AM
HMAC300
  • 48,601 POSTS
sounds like one of your clutch paks are shot or the running clutch. put it in Low and see if it moves if it does then it confirms what I just said were bad. transmission will probably need rebuilt.
Jun 11, 2016 at 5:17 AM
BANKSY44
There is no forward gears at all, but there is not a popping sound or anything.
Jun 11, 2016 at 7:35 AM
HMAC300
  • 48,601 POSTS
if no forward gears then it's probably rebuild time or a valve body problem. have a trans guy look at it. check fluid as well if it's dark brown or black it's no good
Jun 11, 2016 at 8:41 AM
BANKSY44
Appreciate the help, I'll get right on that
Jun 12, 2016 at 10:39 AM
  • 55,711 POSTS
Please let us know what happens so it will help others
Jun 13, 2016 at 1:12 AM
