37391
196,000 MILES
WENDYBERNATH
my 96 jeep cherokee stops running while im driving,then i can start it right back up,changed the distributer,plugs,wires,gas filter,transmission filter.no check engine light comes on,what else can i check??
May 7, 2013 at 2:51 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure and clean throttleplate on both sides with choke cleaner and iac hole
May 8, 2013 at 1:39 AM
WENDYBERNATH
Thank you so much for you advise,we cleaned the throttleplate with choke cleaner and it hasn't stalled since!!!!Thank you ,Thank you ,Thank you!!!!!
May 8, 2013 at 10:21 PM
WENDYBERNATH
I spoke too soon,just tried to go to the store,stalled on me three times,now it doesn't want to start back up right away ,takes about 10 minutes,then it will run as long as you keep your foot on the accelerater and gas it up.I think its the fuel pump,stong smell of gas when engine dies.
May 9, 2013 at 12:00 AM
HMAC300
  • 48,601 POSTS
check the fuel pressure like I said in first response. you may want apro do this for you as it may require an adapter to hook into fuel line.
May 9, 2013 at 2:36 AM
