Not starting
200,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
KURSTIN ALANIS COLBERT
Changed the coils on my car, rewired the wiring harness because it kept blowing a fuse for the coils. so now that that's fixed it's still not starting? What do we need to do now?
Feb 15, 2021 at 4:47 PM
We need to start with finding out what the engine is not getting in order to start. Also, confirm that the security light is not on.
If it is not, then we need to find out if we have fuel, spark, air, and compression. Here is a guide that will help with this:
https://youtu.be/dCjmRL3p4Cs
Start with checking fuel pressure. Here is a guide that will help with this:
Once we know what the pressure is then pull a plug out and hold it against the block then crank the engine to see if it sparks.
Let's start with this and go from there. Thanks
Feb 17, 2021 at 8:45 AM
So the Anti-Theft light is on, it's flashing every few seconds, also I'm thinking I'm going to need to get this PCM flashed so it has all my codes and stuff for my car because it still has all the info from the 2007 Fusion we took it off. What you think?
Feb 25, 2021 at 12:15 PM
You did not mention that you replaced the PCM from another vehicle, so I suspect that is your issue as you are saying.
What is happening is the PCM is looking for the security information from the other vehicle that you removed this from. So you may be able to perform the attached process below. Basically when you replace the PCM you need to "teach" it what the key information is.
So when you turn the key on it sends a signal to the cluster. The cluster then sends a secret code to the PCM to tell it that it is a good key and it is ok to start the vehicle.
You have a PCM that does not recognize the codes that it is getting because it is still programmed to the other vehicle.
The only issue you may have is, I am not sure you can over write this data. Meaning once the PCM is "taught" what the key info is it cannot relearn a new one but it is worth a try.
If this does not work then you will either need to buy an unprogrammed PCM.
Let me know what questions you have. Thanks
Feb 26, 2021 at 10:15 AM
