Engine light on code p0011
177,374 MILES • 2.5L • 4 CYL • AUTOMATIC
RICHARD WILSON6
Had code, Had to change my ignition coil do I did and spark plugs as well? turned car on and drove a half a block engine light came back on and the new code p0011. please help
Sep 2, 2019 at 9:45 AM
  • 110,251 POSTS
Welcome to 2CarPros.
Anytime there is a problem with a coil resulting in a misfire, I replace the plugs. However, in this case the code you have isn't related to the coil or a plug. The code indicates there is an issue with intake valve timing (IVT). Did you do anything to a cam sensor? Is anything disconnected? Is the vehicle running properly?
I attached a pic of the sensor I'm referring to. Check it to make sure it isn't disconnected or damaged. Also, make sure the coolant temperature sensor is connected.
Sep 2, 2019 at 1:00 PM
