Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Suburban
Engine
Symptoms
Not Running
Will not start after replacing ECM
1998 GMC SUBURBAN
144,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
TRAVISJ1988
MEMBER
1 POST
I just replaced the ECM and now my truck will not start.
Mar 24, 2019 at 5:41 AM
JOETECHPRO
Experienced Mechanic
Hey TRAVISJ1988,
The new engine control module will need to be programmed to the vehicle before the vehicle will start.
You will need a scanner with a programming/replacement modules function to do this.
This may need to be done at a GMC dealer.
Regards, Joe
Mar 24, 2019 at 10:32 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
