I have coolant in my oil and oil in my coolant reservoir
190,000 MILES • 4.4L • V8 • 4WD • AUTOMATIC
BETHESTRELLA
No overheating issues.
Nov 18, 2019 at 11:54 AM
Unfortunately this is most like the head gasket. Just because it is not overheating doesn't discount the head gasket. We need to do a compression check and then if there are low cylinders, you need to do a cylinder leakage to confirm the head gasket but I think we can safely assume that after you find low compression.
Let me know if you have questions. Thanks
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Nov 19, 2019 at 10:15 AM
JIS001
  • 3,412 POSTS
If there is no overheating and oil and coolant are mixing I would suspect a faulty oil cooler. The cooler is next to the oil filter. You would need to replace the cooler, change out oil, replace the radiator and heater hoses with expansion tank and flush out the rest of the cooling system.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Nov 21, 2019 at 1:37 PM
