battery, oil and check engine light are on
91,500 MILES
KALESE777
So, this morning I started my car and it was driving fine. I made a quick stop, turned my car off and then turned it back on and the battery, oil and check engine light were on and it was driving very slow as if it was about to run out of gas. My car has plenty of gas, it does not need an oil change and I have not had any major problems before with this vehicle. I then turned the vehicle off, turned it back on and the lights went off and it was driving fine. I would just like to note, that I recently drove from Oklahoma City to Searchlight, Nevada (approximately 1,600 miles) and before I left I had everything looked at and they said it was fine. I would also like to note that I am in 120 degree heat.
Jun 21, 2017 at 1:37 AM
HMAC300
  • 48,601 POSTS
the heat may effect it as well as a battery that is in poor shape or dirty terminal ends. have battery checked for condition including load test. and make sure terminals are clean with no corrosion or grease etc.
Jun 21, 2017 at 2:48 AM
