Will not start after replacing the ignition
15,000 MILES • 0.5L • 6 CYL • TURBO • 2WD • AUTOMATIC
DONNA ROBERTS2
Replaced ignition in it now it won't start. what else can go wrong?
Feb 25, 2020 at 7:36 PM
Good morning,
Did you replace the ignition switch or the key? The key will require a relearn procedure.
There is a 10-minute procedure and a 30-minute procedure post below.
Feb 25, 2020 at 8:29 PM
