Help
FORDF250351HO
  • 1983 FORD F-250
  • 150,000 MILES
I have a Ford F250 351 ho 4 speed that wont go into gear it has a brand new clutch what could it be I drove it yesterday just fine and I set it over night in First and then moved it and then 5 minutes later I went to move it and it wouldnt go into gear or anything
Thursday, May 16th, 2013 AT 8:31 PM
CJ MEDEVAC
  • 11,005 POSTS
4X4?
CLUTCH PEDAL FEEL NORMAL?
MY NEIGHBOR, WHEN I LIVED IN SAVANNAH, GA, HAD SIMILAR SYMPTOMS. FOUND OUT THAT SOMEONE LIKED HIS DRIVESHAFT BETTER THAN HE DID!
CAN YOU ELABORATE ON WHAT IT DOES?
DID YOU CHECK YOUR CLUTCH MASTER CYLINDER FOR JUICE?
THE MEDIC
Thursday, May 16th, 2013 AT 9:54 PM
