Check engine light on and stalling
56,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MARLON GRAHAM
  • 5 POSTS
Well, I woke up today and my check engine light was on. So I started my car and it started right up with no issues. That is until I started to drive it. A few seconds after I left my home the car stalled for a few seconds before coming back to life and driving like normal. So I drove it around for about 30 minutes and there were no issues. So I parked my car again, started it up let it run for about 10 minutes there were no issues, but i back out of the drive way again and I put it in drive and sure enough it stalls again but only for a few seconds then, it goes right back to normal. I have no clue what is causing this, but i have a business trip coming up in a few weeks and I don't have the money to put my car in the shop with these crazy times. I need to first try to fix it on my own. thanks in advance everyone.
Aug 14, 2020 at 5:42 AM
  • 110,246 POSTS
What needs done first is to have the computer scanned to see why the light is on. That should point us in the right direction.
Since you want to do this yourself, see if there is a local parts store that will scan the computer for you. Most do it free of charge. Do that and let me know what codes were found so I can direct you.
Aug 14, 2020 at 5:46 AM
MARLON GRAHAM
  • 5 POSTS
Hey there JACOBANDNICKOLAS. So i got the test done and it comes back as the input speed sensor p0715.
Aug 14, 2020 at 6:53 AM
MARLON GRAHAM
  • 5 POSTS
hey guys, :) I was hoping maybe you guys could link me to the parts i need to correct this issue. Thanks in advance.
Aug 14, 2020 at 7:20 AM
  • 110,246 POSTS
The input speed sensor is near the starter motor. If you look at pic 1, I circled the sensor and have an arrow pointing where the starter would be located.
___________________________
2016 Nissan-Datsun Altima Sedan L4-2.5L (QR25DE)
Input Speed Sensor - Removal and Installation
Vehicle Power-train Management Transmission Control Systems Sensors and Switches - Transmission and Drive-train Sensors and Switches - CVT Transmission Speed Sensor Service and Repair Removal and Replacement RE0F10D - CVT Input Speed Sensor - Removal and Installation
INPUT SPEED SENSOR - REMOVAL AND INSTALLATION
REMOVAL
Remove the battery tray. Refer to Removal and Installation.
Remove the starter motor. Refer to Removal and Installation.
Disconnect the harness connector from the input speed sensor (1).
pic 2
Remove the input speed sensor bolt, then the input speed sensor (1).
Remove the O-ring (2) from the input speed sensor (1).
CAUTION: Do not reuse O-ring.
INSTALLATION
Installation is in the reverse order of removal.
CAUTION:
Apply Genuine NISSAN CVT Fluid NS-3 to the O-ring.
Perform "ADDITIONAL SERVICE WHEN REPLACING ECM". Refer to Removal and Installation
____________________________________
When you reinstall the new sensor, lubricate the o-ring with a small amount of oil.
Aug 14, 2020 at 10:13 AM
MARLON GRAHAM
  • 5 POSTS
JACOBANDNICKOLAS thank you so much. I have to ask one more question. Is it possible that my transmission is bad as well? Or will the provided information you sent for sure correct the issue?
Aug 14, 2020 at 12:31 PM
MARLON GRAHAM
  • 5 POSTS
I’m only asking because a friend of mine said that would be possible.
Aug 14, 2020 at 12:32 PM
  • 110,246 POSTS
Anything is possible. It could be the sensor, wiring, connector, TCM, and so on. Here is my concern: The vehicle came with a 5 year 60,000 mile power-train warranty, so if it is the transmission, it should be covered by the manufacturer's warranty. If you do something wrong, they may void the warranty. What I would recommend is to contact a dealer with your VIN number and confirm it is still under warranty. I don't actually know the in service date, but you are good as far as mileage.
The only way I can confirm would be to have you complete diagnostics. I will provide the directions. I noted you indicated no knowledge, so you may not feel comfortable doing this or have the tooling. Regardless, I want you to have them.
_______________________________________
Diagnosis Procedure
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0715 RE0F10H - CVT Diagnosis Procedure
DIAGNOSIS PROCEDURE
Diagnosis Procedure
1. CHECK PRIMARY SPEED SENSOR POWER CIRCUIT
Turn ignition switch OFF.
Disconnect primary speed sensor connector.
Turn ignition switch ON.
Check voltage between primary speed sensor harness connector terminal and ground.
+ - Voltage
Primary speed sensor
Connector Terminal
F8 3 Ground 10 – 16 V
Is the inspection result normal?
YES >> GO TO 2.
NO >> GO TO 6.
2. CHECK PRIMARY SPEED SENSOR GROUND CIRCUIT
Check continuity between primary speed sensor harness connector terminal and ground.
Primary speed sensor - Continuity
Connector Terminal
F8 1 Ground Existed
YES >> GO TO 3.
NO >> Repair or replace malfunctioning parts.
3. CHECK CIRCUIT BETWEEN PRIMARY SPEED SENSOR AND TCM (PART 1)
Disconnect TCM connector.
Check continuity between primary speed sensor harness connector terminal and TCM harness connector terminal.
Primary speed sensor TCM Continuity
Connector Terminal Connector Terminal
F8 2 F16 35 Existed
YES >> GO TO 4.
4. CHECK CIRCUIT BETWEEN PRIMARY SPEED SENSOR AND TCM (PART 2)
Connector Terminal
F8 2 Ground Not existed
YES >> GO TO 5.
5. CHECK TCM INPUT SIGNALS
Connect all of disconnected connectors.
Lift the vehicle.
Start the engine.
Check frequency of primary speed sensor.
+ - Condition Standard
TCM
Connector Terminal
F16 35 Ground
Selector lever: "DS" position
Vehicle speed: 20 km/h (12 MPH)
Approx. 700 Hz
See pic 1 below.
YES >> Check intermittent incident. Refer to Intermittent Incident.
NO >> Replace primary speed sensor. Refer to Removal and Installation.
6. DETECT MALFUNCTIONING ITEMS
Check the following items:
Harness open circuit or short circuit between ignition switch and IPDM E/R. Refer to Wiring Diagram - Battery Power Supply -.
Harness open circuit or short circuit between primary speed sensor and IPDM E/R.
10A fuse (No.46, located in the IPDM E/R). Refer to Fuse, Connector and Terminal Arrangement.
IPDM E/R
Is the check result normal?
Aug 14, 2020 at 2:32 PM
