Low compression
116,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PINDO
Found out that cylinder one has 150 psi cylinder, two has 130 psi, cylinder three has 30 psi and cylinder four has 0 psi. Cylinder three and four engines are way low on compression. Engine is 2.2 Lite Ecotec.
Thanks, Duane
Oct 19, 2018 at 3:36 AM
Good afternoon.
The cylinder head will have to be removed to determine the failure.
Possible issues:
1. Burned valves
2. Damaged pistons
3. Head gasket failure
You could inject air into the last two cylinders with shop air and see where the leak goes. It could go out the exhaust, back into the intake, out the oil fill cap or out the radiator.
That will give you an idea where the leak is located.
https://www.2carpros.com/articles/the-reasons-for-low-compression
Oct 19, 2018 at 5:32 AM
