i think it went on limp mode. i push on the gas no response. also the lights on the dash go crazy. i cannot go past two miles.
Mar 18, 2019 at 12:56 PM
✓Experienced Mechanic
Good morning,
Is the check engine light on?
You can go to a parts store and have it checked for free. Once you know the code, then let me know so I can narrow down the area of failure.
Mar 18, 2019 at 10:50 PM
This is a common problem and 9 time out of 10. the throttle bore is dirty which causing the computer and throttle actuator to lose correlation making the car go into limp mode. Here is a guide that will help:
