Heavy acceleration rough idle
490,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
BLAKE WILLIAMS
I have a BF Falcon MKII lpg factory inline six.
At the moment i have noticed under heavy acceleration it will rev normal but does not have any power. it will accelerate normal whilst driving casually only suffers at top end power. When i slow down doing less than twenty kph the car will shake only after slowing down after heavy acceleration.
Aug 1, 2017 at 11:51 AM
  • 55,716 POSTS
A couple things come to mind, first is the spark plugs are starting to wear causing the problem.
Here is a guide to help you with that:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Next would be to read the trouble codes from the computer.
Cheers, Ken
Aug 3, 2017 at 4:22 AM
