1983 Ford Falcon Impco 200 LPG Converter
1983 FORD FALCON
BUFFRY
Engine Performance problem
1983 Ford Falcon 6 cyl Two Wheel Drive Automatic
will the gas converter cause poor performance problems
and poor firing problems at idle
Sep 5, 2009 at 1:35 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there.
This may be your problem, you should have the mixture tested, if the converter is an older impco it will be adjustable, but the later units are not, also check that the leads are not cross firing, if they have a lot of Grey residue where they are bunched, replace them.
Mark (mhpautos)
Sep 7, 2009 at 6:03 AM
