engine overheating while idling
109,000 MILES • 4 CYL
RICHN979
I just replaced my thermostat and my car runs fine the temperature gauge is just a little higher than usual almost to the middle. it rises to the middle when I am stopped idling for over ten minutes then it will go down once I drive. It did not use to do this.
Mar 20, 2018 at 2:38 PM
More then likely you got a thermostat that has a higher temp opening point or you have an air pocket in the cooling system.
Let's double check the part number that you have and make sure it is correct.
Here is a guide that will help others with replacing the thermostat if you need it:
Also, here is a guide on how we need to flush the system and make sure it is filled so there are no air pockets:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
If all you did was replace the thermostat and this is happening, the only other possible cause is a faulty new thermostat.
Please see below for the process out of the manual as well.
So let's run through this material and go from there. Let us know what you find. Thanks
Dec 30, 2020 at 7:30 AM
