No heat from vents on passenger side, only driver side.
Nov 19, 2017 at 10:25 AM
KHLOW2008
✓Experienced Mechanic
The air blend door for the passenger side is most probably stuck due to a faulty air blend motor or stuck/dismounted linkages. You would need to check which is the cause.
Nov 19, 2017 at 2:00 PM
GERALDINE1
MEMBER
THANKS GUYS,COULD YOU TELL ME WHERE THE BLEND MOTOR IS LOCATED.
Nov 21, 2017 at 9:13 AM
KHLOW2008
If you look under-dash on passenger side, it should be at side of heater housing, ie near center under-dash.
It should look something like the one in picture.
Images (Click to enlarge)
Nov 21, 2017 at 11:29 PM
GERALDINE1
MEMBER
THANKS FOR RESPONSE,THE ONLY THING THAT LOOKS LIKE THE PICTURE YOU SENT IS BEHIND THE GLOVE BOX UNDER THE DASE FUREST RIGHT SIDE PASSENGER,IS THAT IT?
