heating
142,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
BEN OWINY
hello mechanics thanks for the good work. i drive a 1kz engine that recently overheat and burnt the gasket. we changed gasket,piston rings,piece bearings,serviced cylinder head but the heating just cant go away,there are bubbles from radiator and it coolant dries up so fast without visible leakage.but,there was a visible crack inside the block where pistons sit but my mechanic told me its minor,and also he says its my radiator that needs replacement,if so where does my coolant disappear? please help because this car feeds my little family down here in Uganda(karamoja). peace be with you.
Mar 27, 2017 at 10:39 PM
HMAC300
  • 48,601 POSTS
if there is a crack in the block and your coolant disappears fast then it is probably going there. when car over heats touch radiator in several spots if it feels cold anywhere then the rad is bad as well.
Mar 27, 2017 at 11:09 PM
