Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Matrix
Electrical
Fuse Panel
Location
where the fuse panels check the fuses
2005 TOYOTA MATRIX
139,000 MILES • 4 CYL • FWD • MANUAL
JARETCAL
MEMBER
1 POST
Heater wont work I need to check the fuses where are they and how do you test them?
Nov 16, 2016 at 10:40 PM
Experienced Mechanic
Here is a guide that will help with testing and replacing fuses as it gives step by step instructions:
Below is the info from the manual that will give the detail about these fuses.
Please run through this info and let me know what questions you have. Thanks
Images (Click to enlarge)
Jun 23, 2021 at 5:28 AM
Add image or video
Ask a new question
Engine won't crank
Engine has low power
