Heater, air conditioner and defrost is not blow out air on any setting. Changed fuse, no joy.
Where do I go next?
Nov 19, 2016 at 9:10 PM
BUCHANAN BEATON
MEMBER
1 POST
ive changed the resistor blower motor my climate controls checked each fuse i still have nothing 97 jeep tj
Dec 12, 2019 at 3:17 AM
✓Experienced Mechanic
There is a blower motor relay that needs to be checked and check for power at the fuse and ground at the mother here is a guide to help you test the system and the blower motor wiring diagrams below so you can see how the system works.
