Heater valve removal and installation
2012 NISSAN TITAN
110,000 MILES • V8 • 2WD • AUTOMATIC
TONTO69R
Heater is blowing cold air. Took to shop and found out it’s the heater valve. Can it be changed without changing the hoses or do I need to change everything out? Where can I find a diagram to help with that?
Jan 17, 2020 at 10:30 AM
  • 110,190 POSTS
I need to confirm something. Was it the air mix door actuator they referred to? I don't believe this vehicle has a true heater control valve. They have referred to it as a blend air door actuator.
Jan 17, 2020 at 9:30 PM
