heater shuts off engine “i think”?
150,000 MILES • 2WD
DANIKQUA THOMAS
so, i can use the heat/AC when my cars parked but it will not drive if the heater/AC is on. it has never done this before I'm the cars second owner if i do try driving while the heats on the car stalls out and it turns my engine and fluid lights on.
Feb 24, 2023 at 6:58 AM
  • 110,248 POSTS
This is likely a power issue. Have you had the battery checked (load tested)? Also, you may have a weak alternator. Take a look at this link. It explains how to test one. All you need it a voltmeter or multimeter.
Does the engine run normally when driving if the heater is off?
Let me know. Also, let me know if the check engine lamp stays on with the engine running.
Feb 24, 2023 at 1:51 PM
DANIKQUA THOMAS
yes, the engine runs normally and no, the light doesn’t stay on.
Feb 24, 2023 at 11:42 PM
  • 110,248 POSTS
Wow, this is interesting. The two circuits aren't connected. That is why I'm thinking it may be a voltage issue.
Were you able to check the alternator output using the link I attached above?
Feb 25, 2023 at 1:44 PM
