heater return line broken
150,000 MILES
BUZHOD
Where the heater return line connects to the back of the water pump housing, the tubing that is pressed into the housing is broken.
Sep 29, 2016 at 8:05 AM
WRENCHTECH
  • 20,760 POSTS
If it is pressed into the housing, then you need a new water pump.
Sep 29, 2016 at 9:17 AM
BUZHOD
It is not the replaceable part of the water pump it is the housing or body of the pump.
Sep 29, 2016 at 9:33 AM
WRENCHTECH
  • 20,760 POSTS
If it is a separate housing, then you need the separate housing. If it is not a normal wear item that would be sold aftermarket, then you may have to go to the dealer to find it.
Sep 29, 2016 at 9:39 AM
