Heater problems
PAUL SUNDSTROM
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 80,000 MILES
I have a 2000 Elantra, I replaced the thermostat and have no heat. Is there a place to bleed the air out of the cooling system.
Friday, February 12th, 2021 AT 11:14 AM (Merged)
DAVE H
  • 13,384 POSTS
DRAINING
Remove radiator cap and open heater control valve to maximum heat position. Open drain cocks or remove plugs in bottom of radiator and engine block. In-line engines usually have one plug or drain cock, while "V" type engines have 2, one in each bank of cylinders.
REFILLING
To prevent air from being trapped in engine block, engine should be running when refilling cooling system. After system is full, continue running engine until thermostat is open, then recheck fill level. Do not overfill system.
