Heater blowing out cold air
103,795 MILES • 4.6L • V8 • 2WD • AUTOMATIC
OMAR'SDTS
My car's heater blows out cold air and the A/C works fine, just no hot air...
Mar 16, 2021 at 11:54 PM
There are normally a couple reasons for this. Here are some guides that will help with this:
https://www.2carpros.com/articles/car-heater-not-working
https://youtu.be/SNRb6pSwYuU
Clearly the most likely cause of this is a blend door issue so let's start with that.
https://youtu.be/Eqf-H3COtSo
Below you will find the process from the manual. If it were me, I would start with this after you check the heater hoses going into the heater core. Turn the engine on and get it hot and then put the heat on full hot and then feel both hoses. They should be hot. If they are not then we have a coolant flow issue. Either the heater core itself if one hose is hot, or a supply issue.
Let me know if you have questions. Thanks
Mar 18, 2021 at 9:08 AM
