HEATER PROBLEM
170,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
HARRY ELLIOTT
Heater puts out heat when first turned on then goes cold and the water level is full.
Oct 30, 2016 at 11:29 AM
HMAC300
  • 48,601 POSTS
pull HVAC fuse inside car for sixty seconds with key on then reinstall it may reset actuators . if this does not work then it must be scanned for codes to see if actuators are getting power. a mechanic has to do this.
Oct 31, 2016 at 12:08 AM
HARRY ELLIOTT
I can not find an HVAC fuse. The only fuse box is under the hood and there no HVAC fuse in that fuse box.
I find no fuse box inside of the car.
Oct 31, 2016 at 1:00 PM
HMAC300
  • 48,601 POSTS
try pulling fuse forty under hood for same result. then have it scanned for codes by a mechanic.
Oct 31, 2016 at 10:32 PM
HARRY ELLIOTT
do you mean a forty amp fuse as there is no position forty in the fuse box.
Nov 1, 2016 at 5:54 AM
HMAC300
  • 48,601 POSTS
sorry, I meant fuse ten as it is a forty amp fuse. just pull it out for sixty seconds and reinstall and see if that resets actuators if not you will need to get a mechanic scan for codes.
Nov 1, 2016 at 6:21 AM
