Heater problem
203,000 MILES
JAMESNYDER
  • 12 POSTS
The heat just stopped out of know where it started getting cold in the morning and it was hot in the afternoon. the first few times I had taken the control for the heater all the way down and then back up to get it to work, but now if I put it on ninety it is still blowing out air at sixty degrees. I am going to the junk yard tomorrow so suggestions would be great. thank you.
Sep 28, 2016 at 7:52 PM
HMAC300
  • 48,601 POSTS
scan for codes first, a mechanic has to do this as it is an automatic temperature control. also, check fluid level.
Sep 28, 2016 at 11:07 PM
JAMESNYDER
  • 12 POSTS
I have a 2005 Ford free star van the AC is coming up threw the defrost and not the dashboard vents
Jun 15, 2017 at 4:09 AM
HMAC300
  • 48,601 POSTS
y pulling hvac fuse inside car with key on for 60 seconds it may reset the actuator . if not you'll have to check for a bad actuator which is in center of dash. however if auto temp control a mechanic should scan this to see if something else. see piic
Jun 15, 2017 at 5:11 AM
