Heater outlet Pipe connector to engine
150,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
RAILROADERTWO
  • 42 POSTS
I did not realize this connector was a quick release lock type, and I guess I broke it when I removed it for a intake manifold gasket replacement. I am going to get a new one.
What the correct way to install the pipe to the connector? Install the connector to the engine, then insert the pipe in the connector, or put the heater pipe tube in the connector First. Thanks
Dec 19, 2014 at 1:36 PM
FREEMBA
  • 1,152 POSTS
Install the connector into the engine the install the pipe into the connector.
Dec 19, 2014 at 9:15 PM
RAILROADERTWO
  • 42 POSTS
Thank You
Dec 20, 2014 at 1:10 AM
RAILROADERTWO
  • 42 POSTS
I'm 70 years old, I did all my repair work, the cars that I worked on did not have quick disconnects.
Dec 20, 2014 at 1:17 AM
