My heater will only blow hot air when I am driving and have my foot on the gas pedal.
Jan 2, 2016 at 7:03 AM
✓Experienced Mechanic
make sure the coolant level is correct. if it is then it sounds like your heater core is partially blocked with debris. you can flush it out by removing the hoses and using a garden hose to flush in both directions.
