heater only works on high
76,200 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
SCHAEFERBOY
Heater only worked on high. i put a new resistor in as suggested and the heater worked fine for about a week and then it went back to working on high only again. Any help would be greatly appreciated. Thanks, Tom B.
Dec 27, 2016 at 10:34 PM
WRENCHTECH
  • 20,758 POSTS
That would mean that the blower motor is drawing too much current and burning out the resisters. You need to change both the blower motor and the resister at the same time.
Dec 27, 2016 at 10:43 PM
WRENCHTECH
  • 20,758 POSTS
Also, make sure none of the plugs have been overheated causing a bad connection which will increase resistance.
Dec 27, 2016 at 10:44 PM
