Heater not working properly
220,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
URBANDORK
Blowing cold air. Mode doesn't change which vents blow air. Replaced heater control valve- didn't help. Smell of burnt antifreeze in engine compartment, but no leaks observed.
Nov 2, 2017 at 10:14 PM
  • 31,937 POSTS
First check that you do have circulation through the heater core, both hoses should be hot to touch at normal operating temperature. if not you will have a blocked heater core, they often flush clean fairly easily, check this first.
Nov 3, 2017 at 9:48 AM
