the heater is blowing hot air but only for 10 seconds?
100,000 MILES • 1.7L • 4 CYL • TURBO • 2WD • MANUAL
ALBAN74
I recently bought a Zafira B 1.7 diesel 2011.
I have a problem with my heater.
When the engine is hot (it does take a fair while to get hot), the heater is blowing hot air but only for 10 seconds and slowly goes back to cold.
I have changed the thermostat, flushed the heater core, and checked the motor that controls the hot to cold air flap just to make sure, and it all functions.
I imagine the coolant warms up the heater core, but heat is not replenished fast enough from the coolant to keep the heating blowing hot.
When I flushed the heater core, no "dirt" seemed to have come out of it and the flow of water was coming out of the core as fast as it would from my hose.
Also, the coolant in the expansion vessel is still dead cold after 20 miles drive. The engine is hot, showing around 90⁰ on the ob2 reader (not overheating then) but the coolant in the vessel stays cold. It will eventually warm up after quite a long drive, way more than on my ford transit or the golf I had previously.
The expansion vessel seems to empty fast enough when opening the drain plug, indicating that it shouldn't be a clogged pipe.
I am going to try a coolant system cleaner just to make sure all residues are dissolved and disposed of but I doubt it will work as it does not seem to come from a restricted flow of coolant.
I believe the water pump is working as the engine is running at 90⁰ and staying at this temperature while driving, unless the engine cools itself down only by convection, but unlikely.
I have the Haynes book for it and it doesn't say anything about bleeding the system on the 1.7l engine (only the 1.9l has a bleeding screw on the exhaust manifold apparently).
I am running out of ideas on what it could be.
Your help would be greatly appreciated.
Many thanks,
Alban
Feb 7, 2025 at 5:13 AM
  • 55,711 POSTS
It could be the head gasket is blown and filling the cooling system with exhaust gasses. I would start by opening the cooling system (cold) then start the engine and allow it to get hot, then have the heater on full and jack the front of the car up, and then the rear to try to get any air bubble out of the system. please go over this video and guide as well:
https://www.youtube.com/watch?v=SNRb6pSwYuU
and
https://www.2carpros.com/articles/car-heater-not-working
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Feb 8, 2025 at 2:42 AM
ALBAN74
Thank you for your answer.
I did see on a post somewhere about doing the jacking up to burp the system, but I didn't think it would be necessary for me as I live in an area where hills are an everyday drive. I will try to do it anyway and come back to you.
Feb 9, 2025 at 3:34 AM
  • 55,711 POSTS
Yep, it is strange, but it works pretty well.
Feb 10, 2025 at 1:41 AM
