heater stopped working after changing the orifice tube
2006 KIA SORENTO
148,947 MILES • 2.6L • V8 • 2WD • AUTOMATIC
NATHANIEL JOHNSON2
after changing the orifice tube on my car the heater stopped working.
I am still having problems with the air conditioning. also, I did not change the dryer filter.
Oct 23, 2016 at 1:42 PM
HMAC300
  • 48,601 POSTS
for air conditioner problems it has to be performance tested to see what is wrong. if it works for a while then quits cooling it probably has moisture in system and needs pumping down then recharged along with a dryer replacement at minimum. for heat try pulling HVAC fuse in car with key on for sixty seconds then reinstall and it may reset actuator.
Oct 24, 2016 at 12:28 AM
