Heater not woorking properly
205,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEMURPHY46
The heater gauge does not increase while driving and the heater puts out low heat. If I idle for a few minutes the gauge increases and the heater output increases. When I drive again, the original conditions return. Can you offer a solution?
Dec 11, 2017 at 10:30 PM
CARADIODOC
  • 34,415 POSTS
Replace the thermostat. This used to be a real common problem on every brand of vehicle, but today, with all the complicated and unreliable computer controls, those cause the majority of heater problems. The clue this is a simple, less expensive problem is your observation the temperature gauge is too low. Cannot get hot air if the engine coolant heating that air is not hot enough.
Dec 12, 2017 at 5:36 AM
