Heater not blowing warm air
137,000 MILES • V6 • 2WD • AUTOMATIC
KIMCHESSER31
My car just got out of shop from getting the transmission worked on and my heater worked great before it went into the shop and now it doesn't. what happened?
Oct 22, 2019 at 2:30 PM
I am assuming there is air coming out of the vents, it is just not hot? If this is the case, what work did they do to the transmission specifically?
The heat is produced by air being pushed over the heater core in the dash board so I would assume there is an issue with the coolant going through the heater core. However, most transmission work doesn't require this to be tampered with.
Knowing what they did may help this. Thanks
Oct 23, 2019 at 9:06 AM
