Heater not blowing hot or warm air
150,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
RANDY1955
  • 71 POSTS
My heater is not blowing hot air just cool air. What is the problem?
May 25, 2020 at 6:09 AM
  • 110,246 POSTS
It could be a few things. First, confirm the engine coolant is full. Also, take a look through this link and see if anything helps:
https://www.2carpros.com/articles/car-heater-not-working
Next, try this and let me know the results. Allow the engine to warm up to operating temp with the heater on high. Once operating temp is reached, turn the engine off and carefully touch each of the two heater hoses where they attach near the firewall. Both should be hot.
If they are hot, then suspect a blend air door actuator isn't working. If the coolant is full and only one hose is hot, suspect the heater core is plugged.
May 25, 2020 at 12:49 PM
RANDY1955
  • 71 POSTS
Yeah, both heater hoses are hot. so blend door huh, could that cause my A/C not getting cold because it just blows warm air? And thank you again for all the help.
May 26, 2020 at 9:46 AM
  • 110,246 POSTS
The blend air door is what determines the air temp that enters the vehicle. It can affect both heat and A/C.
Here is a link that shows in general how one is replaced:
The actuator is under the dash (near center). I attached a pic to help you locate it.
Let me know if this helps.
May 26, 2020 at 2:47 PM
