Heater not blowing hot air
200 MILES • 4WD • AUTOMATIC
HOLLI WILLIAMS
Heater blower is blowing cold air, but the control panel on the Inside of truck and all the lights are on and all the way across from cold to hot are lit up and it cuts off after a few minutes.
Jan 17, 2018 at 4:54 AM
CJ MEDEVAC
  • 11,000 POSTS
I may not be your answer, but surely someone else on my end may be, if they jump into this thread if I get stumped!
(our end may need this "initial" info regardless)
It blows cold air and then the blower stops blowing?
Do you still hear the fan running when the air stops blowing?
Or is it the fan that stops all together (thus the air quits too)?
Was this a sudden occurrence?
Anything else you might add may be helpful!
The Medic
Jan 17, 2018 at 7:08 AM
JAMIECONWAY88
  • 6 POSTS
There are four main cooling system problems that can cause a heater to blow cold:
- Stuck thermostat.
- Air in the cooling system.
- Plugged heater core.
- Coolant not flowing through the heater core.
It is a little more complicated than that in practice, but these are the most common issues that you will run into.
Try to check these things and maybe you can fix it. Hope this will be helpful for you someway!
Jan 17, 2018 at 12:16 PM
  • 55,748 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Jan 20, 2018 at 7:01 AM
