heater hose assembly
140,000 MILES • 0.5L
IMAHERE222
You guys did an install one one of these assemblies on YouTube.
1993 to 2001 Camero Iroc. It's the same as my 1994 Firebird Formula. I purchases a heater bypass hose and am trying to find out two things. The cost of the hose assembly and the id of the intake and output hoses?
Hope to hear from you soon. Thanks, Wm Ishmael
Jun 4, 2019 at 3:34 AM
Good afternoon,
The inside diameter is 3/4.
What engine for the bypass hose?
Jun 4, 2019 at 6:13 AM
IMAHERE222
Roy,
One hose looks larger? The one on the right if you are look from the front of the car?
Engine is 5.7ltr.
Jun 4, 2019 at 6:38 AM
Can you attach a picture of what you see?
Jun 4, 2019 at 6:43 AM
IMAHERE222
No I can't Roy. I'm an old guy and still have a flip phone. 1994 Pontiac Firbird Formula 5.7 Ltr with overdrive. The reason I'm asking is for two reasons. The bypass hose I purchased is 3/4" id and 5/8"id on the other side and the hose is shaped like a "U" and if I get them loose and may and have to cut and shorten one hose on the car. I want to know what a replacement assembly would cost and when I do get it apart I want to make sure my straight fittings for hose to hose connection are the right size.
Thanks again
Jun 4, 2019 at 6:55 AM
Got it.
That hose is correct. The 3/4 part goes to the water pump and the 5/8 goes to the intake side.
A picture would help a lot. Maybe you could get someone else with a better phone to take a picture.
Jun 4, 2019 at 7:19 AM
IMAHERE222
https://www.youtube.com/watch?v=lwtDjEk5qXY
Try this for now, the assembly is correct at the firewall, but from there it goes down and I can't see that until I get it put on a lift. Thanks again, and I'll try something on that picture.
Jun 4, 2019 at 7:51 AM
Those are heater hoses, not bypass hose as you requested.
Yes, you need to get the bolt from the bottom for the mount.
They are predetermined sizes for the hoses and they only go in one place.
Jun 4, 2019 at 7:59 AM
