HVAC not blowing air and no heat from the heater?
150,500 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JAY73
No heat, no air will come out of the A/C or heater.
Feb 10, 2021 at 11:28 AM
Good morning,
I attached a wiring diagram for you of the blower motor system. You need to check for voltage to the blower motor.
It could be either the blower motor or the resistor.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
BLOWER MOTOR REPLACEMENT
REMOVAL PROCEDURE
1. Remove the right side instrument panel insulator.
2. Disconnect the blower motor electrical connector.
3. Remove the blower motor mounting screws.
4. Remove the blower motor.
Feb 11, 2021 at 12:48 AM
