Heater display fail
220,000 MILES • 5.3L • V6 • 4WD • AUTOMATIC
SCOTTSCOTT07
  • 21 POSTS
The other day I was driving around when I went to switch my heater from defrost to feet and body then switch it to high and as soon as I hit the high button the whole display shut off. I have checked the fuse and that is okay, but I was told by a friend it might be a control box kind of deal that went out. I am just trying to find somebody that has had this problem and knows the fix.
Additional information:
The heater has always seemed weak in low and medium setting I have not owned this truck long so this is my first winter with it.
I have also tried disconnecting the battery to try to reset the controller still no power to the unit.
Jan 7, 2017 at 4:44 AM
DOCFIXIT
  • 18,828 POSTS
Check instrument panel fuse. Do the dash lights operate?
Jan 7, 2017 at 5:04 AM
SCOTTSCOTT07
  • 21 POSTS
yes, lights work and fuse is good.
Jan 7, 2017 at 5:42 AM
SCOTTSCOTT07
  • 21 POSTS
I found something I did not see before. The fuses in my instrument panel are not all the right sizes. I have a thirty in the heater/air conditioner spot instead of a twenty five and others are the same, I am going to get those corrected now.
Jan 7, 2017 at 5:56 AM
DOCFIXIT
  • 18,828 POSTS
Hey so did fuses work?
Jan 8, 2017 at 3:42 AM
SCOTTSCOTT07
  • 21 POSTS
No still no display on the heater unit
Jan 9, 2017 at 6:14 AM
DOCFIXIT
  • 18,828 POSTS
Do you have a DVOM? Can you remove control head and do some voltage tests. I can help through it
Jan 9, 2017 at 6:18 AM
SCOTTSCOTT07
  • 21 POSTS
I can get one and that was my next step just waiting to hear back from him I'll let u know when I have it
Jan 9, 2017 at 6:25 AM
SCOTTSCOTT07
  • 21 POSTS
I've got the meter and control disconnected
Jan 9, 2017 at 8:13 AM
SCOTTSCOTT07
  • 21 POSTS
The 3 on the top left and the top and bottom far right are hot
Jan 9, 2017 at 8:27 AM
DOCFIXIT
  • 18,828 POSTS
Then it is not an electrical issue so looks like control module is faulty
Jan 9, 2017 at 9:03 AM
