HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Cadillac
Deville
Climate Control
Heater
Heater Core
SPONSORED LINKS
Heater core replacement
JEFFREYMW
MEMBER
1995 CADILLAC DEVILLE
4.9L
V8
2WD
AUTOMATIC
60,000 MILES
How much time should it take for a trained mechanic to replace a heater core in the car listed above?
Sunday, February 11th, 2018 AT 4:50 PM
MECHANIC
Good evening.
2.5 hours is the standard repair time.
SPONSORED LINKS
Sunday, February 11th, 2018 AT 5:22 PM
JEFFREYMW
MEMBER
Thanks for the response!
Much appreciated.
Sunday, February 11th, 2018 AT 5:33 PM
MECHANIC
You are welcome.
Sunday, February 11th, 2018 AT 5:37 PM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
Heater Core Removal
How Do You Remove The Heater Core. What Do You Have To Remove To Get It Out. How Much Work Is It. Thank You
Asked by
Plymouth31
7 IMAGES
2000
CADILLAC DEVILLE
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
1990 Cadillac Deville Heater Core
Engine Cooling Problem 1990 Cadillac Deville V8 Automatic 129000 Miles I Have A Sedan Deville, When I Start It Up I Smell Antifreeze...
Asked by
prkje283
1 ANSWER
1990
CADILLAC DEVILLE
1992 Cadillac Deville Heater Core Problems
High I Have A 1992 Cadillac Deville. I Had A Flush And Water In The Cooling System. The Heat Ran Hot It Was Nice On Cold Days To Have Heat....
Asked by
sean03
1 ANSWER
8 IMAGES
1992
CADILLAC DEVILLE
1996 Cadillac Deville Heater Core
Engine Cooling Problem 1996 Cadillac Deville V8 Two Wheel Drive Automatic How Do I Bypass The Heater Core, The Car Keeps Overheating...
Asked by
jakepalmher
1 ANSWER
1996
CADILLAC DEVILLE
2001 Cadillac Deville By-pass Heater Core
We Have A 2001 Cadillac Deville. After 5mins Of Driving The Car Overheats. We Want To Bypass The Heater Core. Please Suggest The Best Way...
Asked by
tangolee
1 ANSWER
2001
CADILLAC DEVILLE
VIEW MORE
SPONSORED LINKS
Heater Hose Replacement Chevrolet Camaro
Coolant Leak Symptoms
Online car repair manuals
