Heater core removal
185,700 MILES • 3.1L • V6 • 2WD • AUTOMATIC
FORDTECH55
What needs to be removed to get to the heater core on my car listed above it is a sedan?
Dec 30, 2017 at 3:07 PM
Good morning.
Below is the procedure for removal.
Removal:
1. Disconnect battery ground cable.
2. Drain cooling system.
3. Raise and support vehicle.
4. Disconnect heater hoses from heater core assembly.
5. Remove drain tube.
6. Lower vehicle.
7. If equipped, remove console as follows:
a. Apply parking brake and block drive wheels.
b. Position trans-axle shift lever in neutral.
c. On models with automatic trans-axle, remove clip retaining shift lever handle to lever, then remove shift lever handle.
d. On models with manual trans-axle, turn shift lever handle counterclockwise to remove from lever.
e. On all models, carefully pry upward on outer edges of console trim plate.
f. Disconnect electrical connectors and ashtray lamp from console trim plate, then remove trim plate from console.
g. Remove console to mounting bracket attaching screws, then remove console.
8. Right and left sound insulators.
9. Steering column opening filler.
Floor Air Duct Outlet
imageZoom/Print
10. Floor air outlet duct.
11. Heater core cover.
12. Heater core mounting clamps and remove heater core.
Dec 30, 2017 at 7:35 PM
