Heater core hose routing diagram needed
225,000 MILES
KYLE LANC
  • 8 POSTS
Trying to find out which hose goes on which pipe. Everything I find has heater core nipples top and bottom on my van its left and right so not sure which is inlet and outlet.
Apr 28, 2019 at 3:22 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Not a problem. If you look at the attached picture, it shows coolant flow through the heater core. The left side is supply and right is the return.
Let me know if this helps.
Apr 28, 2019 at 1:43 PM
KYLE LANC
  • 8 POSTS
I have a 97 dodge van 2500 and it keeps getting hot. I have put a new fan clutch a new heater core a new thermostat. It’s not losing water I can see water circulating in radiator and there is no water in oil or oil in water. I’m at a lose as to what is causing it and what else to someone please help. This is a photo of temp gauge at about 70 mph on interstate
Apr 30, 2019 at 9:42 AM
  • 110,248 POSTS
Welcome back:
Since you replaced all of that, I have to ask if you flushed the cooling system, both the radiator and engine block? Is the belt turning the water pump tights? How hot does it get when driving in town or stop and go traffic? Also, check to make sure there is nothing preventing full air flow through the radiator such as dirt. If the cooling fins on the radiator seem plugged, spray them clean with water.
If you haven't flushed the cooling system, there could be a partial blockage in the radiator or block. I would suggest doing it. Here is a link that shows how it is done.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Apr 30, 2019 at 12:23 PM
KYLE LANC
  • 8 POSTS
No I haven’t flushed it since I replaced almost everything and it gets hotter when driving at higher speeds when driving around town it doesn’t get to hot
Apr 30, 2019 at 1:24 PM
  • 110,248 POSTS
Try flushing the system. Follow the link I added. Honestly, since it is worse at highway speeds, something is most likely restricting flow. Also, make sure nothing is blocking air from going through the radiator.
Let me know if I can help.
May 1, 2019 at 11:18 AM
KYLE LANC
  • 8 POSTS
Nothing blocking airflow at all checked and blew out radiator and ac coils just to make sure. Gonna tru to find a different link that I don’t have to pay for
May 1, 2019 at 11:28 AM
KYLE LANC
  • 8 POSTS
Thank you by the way I appreciate it
May 1, 2019 at 11:29 AM
  • 110,248 POSTS
Kyle, you are very welcome. Let me know the results.
May 1, 2019 at 11:52 AM
