After replacing the heater core it hesitates and smokes after running for a awhile?
164,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
LARRY M HARRISON
The car listed above is a GS model. I changed heater core and assembly now it hesitates and smokes when running awhile on the side the water pump on.
Mar 21, 2021 at 12:05 PM
Good morning,
Check the hoses for leaks around the heater core are. You need to pressure test the system.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/replace-heater-hoses
I attached a YouTube video of the heater core procedure below.
https://www.youtube.com/watch?v=iqCQpsGY49I
Mar 21, 2021 at 10:14 PM
