Heater control valve
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
INSULMAN1
Can I eliminate the heater control valve by just running new hose, or putting two pieces of pipe in its place?
Nov 12, 2017 at 6:16 PM
  • 55,743 POSTS
You sure can, but the air conditioner will not work as well. The valve is used to cut off the hot engine coolant when the air conditioner is in use.
Cheers, Ken
Nov 13, 2017 at 4:51 AM
