Heater control
26,500 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
48BWRICH
When heat is directed to the floor there is still some coming out of the panel. Is this an actuator problem if so, which one?
Dec 7, 2019 at 5:47 AM
  • 110,248 POSTS
Chances are the mode door actuator needs calibrated. The vehicle is still under warranty. Have you contacted a dealership? They should take care of it for you.
Dec 7, 2019 at 3:06 PM
48BWRICH
What is involved in the calibration? How long would it take to have it done at the dealer?
Dec 7, 2019 at 10:47 PM
  • 110,248 POSTS
Basically, a scanner is used to do it. It requires a high end scanner and not one that you can buy at a parts store.
Dec 8, 2019 at 11:47 AM
